I assume this should light up with the rest of the dash when the headlights are on? Mine doesn't, so working on the idea there is a bulb in it that has blown, can someone please tell me how to get the unit out?
I just don't want to take apart any more than is necessary!
Head light & fog light unit
E30Mark
There should be a light that comes on with the ignition.
The lamp push fits into a plastic 'light pipe' you might be able to just pull the lamp out without removing the switch panel.
If you need to remove the panel, then you need to drop the panel above the pedals, then remove the trim between the dash and the steering cowling. Next you need to loosen the 2 nuts on the back of the foglight / headlight mounting panel, once loose slide the panel to the centre of the car and it should drop out... You might need to remove the headlight knob, this unscrews anti-clockwise. Next you can push in the tab retaining the light switch.
Sorry no photo's but i've just posted my spare bits off to someone! I had to do this the other night in the freezing cold...
PM for details
PM for details
ShineOn
Top man, thanks for that. I shall have a go tomorrow. I don't mind taking these things apart, but I just didn't want to do it if it was never supposed to work that way in the first place!
