I changed my diff sometime last millenia and the cable broke off and fell into space (lost) when I removed the plug for the speedo sensor.
Rather than chop another corroded wire/broken plug from a scrappy car, I thought I'd buy new connectors and fit some new wire; trouble is I cant find the appropriate clips/plugs on RealOEM.
Can anyone tell me the part numbers of the two metal 'prongs' and the plastic cover for the plug for the speedo sensor on the diff. I'll need it for the MOT (he pulled me up on it last time and I said it was cos I hadn't got round to it, etc so he let me off on the condition I fix it asap!).
Many thanks to anyone that can help!
Jai
Help finding part numbers for connectors...
jaistanley
sam325is
had a similar problem with a few broken of plugs on my car. ring your dealership and they sell them. however they look hard to fit(not the plastic casing though). the dealership said take my loom into them and they will do it in the parts dept. or you can take your car to them.
but if you feel you can do it yourself just buy the plugs from them.
jaistanley
I can do it myself, crimping/soldering etc isn't too taxing. I just need the part numbers to get them from the parts department. No offence to anyone who works for BMW spares, but every time I have relied on them to get the part number and supply the bit, I've been mucked around and got wrong bits etc. They quoted me £500 for an ECU relay the other day. I laughed, then I swore.
Can anyone help?
Jai
Can anyone help?
Jai
ian332isport
Jai,
The electrical contacts themselves are 61 13 0 007 446. If my memory serves correctly, the plastic plug housing is white, in which case you need 61 13 1 378 417. If it's grey then it's 61 13 1 378 418. I think it's the same plug that's found on the fog lamps.
Ian.
Ian.
jaistanley
Ian, as per usual, you are a star....
Mines an American M3 diff (4.1 LSD) and I beleive the connector/socket is white.
Many thanks!
Jai
Many thanks!
Jai
