Hi .
can i fit slave cylinder on clutch pedal from any E30 into E30 M3 ? or it must be spesific to this car.
i got some leak on clutch pedal, very tiny i think it's coming out from slave cylinder . well i think it's connected to brake fluid tank. so clutch is hydrolic assisted.
thanks
CLUTCH PEDAL LEAK
dn808e2
Templ8e30
Pretty certain it'll be the same, all the other E30 models use the same cylinder.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
gcorky
- Boost Junkie
gcorky
- Boost Junkie
dn808e2
yeap
