I thought it might just be a process of seal/pressurise/measure loss. Anyone know for definate?
Pressure/Crack Testing of Heads
adamS
Does anyone know how this is done? Googling looks like it involves water.
Templ8e30
Think it involves compressed air, bolt it down to a test bed then pressurise it and close the valve. If the pressure drops then it's a leaker.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
adamS
Cheers Iain
- **BANNED**
When I had a head pressure tested,the water galleries were filled with compressed air,then water was sprayed onto the head.Where bubbles could be seen revealed where the crack was.Mine was at the back of the cam carrier,between 5@6.
Test cost £25.
