I trust you have had a good weekend and are ready for the working week ahead
I had my front wishbones replaced a month ago.
Steel for steel.
Since then I have noticed an incress in Judder when braking.
( Judder was slight B4 I got the wishbones replaced )
The discs have a slight ripple to the touch.
I was wondering if it is the tie rod ends that are causing this issue?
I want to replace the discs but would like to find the cause of the juddering first.
How can I test the tie rod ends?
What do you think is causing the judder?
Cheers.
