Extremely rare but very serious problem!
Dante
Post Sun Jan 28, 2007 11:41 am
Hi to all zoners!
my e30 318is has some problems when i'm stuck in heavy traffic. When it's "hot" outside (say about 20 celsious) and I 've been idle or barely moving in traffic the revs suddenly increase to about 1100rpm then decrease to 500 and then come back to normal.
The idle becomes very unsteady and the car starts shaking a bit! I push the throttle, I leave it and the revs go down to 500 again and come back to 850..
During last summer, again in heavy traffic, the engine just shutted off!
Any ideas? :( :(
stuartgallafant
Post Sun Jan 28, 2007 11:45 am
well i think its definately temperature realted!!
possibly a faulty or stuttered signal from the engine temp sensor to the DME? maybe, i dont really think so, but maybe something to do with the viscous fan coupling?
what kind of conditionis the car in? how many miles? regular service? etc...
markus_74
Post Sun Jan 28, 2007 11:54 am
stuartgallafant wrote:well i think its definately temperature realted!!
Please, check the temperature gauge, if it is more than the red zone, so there is a problem in the
1.Viscous coupling
2.Thermostat stuck
3.Water pump is fail
To know which is fail then must to check one by one.
1.Viscous coupling fan (try to move the fan if the engine is off, if there is no drag or feel light this can be fail)
2.Thermostat stuck try to feel the radiator if the engine is hot but the radiator is still cool then the thermostat is fail
3.Water pump try to run the car if the temperature down after the car move so may be the water pump
But for point 1 and 3 it is better to replace it all in the same time.
I hope this help
Rgds
Markus P Nugroho
reggid
Post Mon Jan 29, 2007 1:27 am
how about the Idle control valve (ICV)?
Dante
Post Mon Jan 29, 2007 3:18 pm
The thermostat is new, I changed it about 2 months ago. The viscous seems ok, I had it checked in a bmw specialist. The temperature gauge is always in the middle which is perfect.
The car is taking about 3-5 minutes more than the other cars to warm up but I guess this is nothing to worry about, right?
I thought about the ICV because it's rev-related and the air flow meter :(
stuartgallafant
Post Mon Jan 29, 2007 4:05 pm
mine was taking about the same amount of time to warm up as yours, it turns out the thermostat and the viscous fan were shagged
