Is there anything I should look for over the standard e30 problems?
any noises that are untoward?
Are the gearboxes a bit notchy and tight?
(might just be me changing gear cack handed)
any common faults? anything to watch specifially?
cheers lads
help: buying 1989 M3 2.3
Bob_S
Bollocks to this 24v scrap!
maxfield
Engines are pretty tappy anyway so don't worry about that
The gearbox should be ok
Let the owner take you out in the car and if he drives it pretty quick from cold then walk away
but i think the biggest issue is rust scuttle is a big one.
im sure there are more things people will add to this
