BMW specialist in Brighton? Engine dosent go over 1500 revs
hafael
Post Sat Jan 27, 2007 8:50 pm
I swap engine (friend of mine did it) in my 325i auto because in old one head gasket blown, new engine is from 325i manual year the same. engine start but not going higher than 1500 revs I tried swap ECU but effect is the same, please help, I could put my car in BMW service but I'm scary about costs I've spent too much already. This car is lovely but makes me frustrated it worked only 3 days from buying an after head gasket blown and still dosent work properly
P.S. Sorry for my english I'm Polish
Raf
d6dph
Post Sat Jan 27, 2007 9:05 pm
Have you tried a good air flow meter, This sounds like when I forgot to plug mine back in :o:
Post Sun Jan 28, 2007 7:50 am
i think afm's are diff, make sure your using the auto one
Post Sun Jan 28, 2007 10:09 am
Welcome to the zone!
This really does sound like the AFM is not connected. Check the connector is plugged in properly, and every other connector as well. Check for inlet side air leaks as well.
If the AFM is connected, then unplug it and start the car without it to see if it makes any difference.
Auto AFM might be slightly different from manual, but not enough to make any significant difference.
TPS is different though on cars with a switchable auto box.
hafael
Post Sun Jan 28, 2007 1:59 pm
cheers guys for quick reaction I hope you have a right It sounds like nothing seriously, so I cross the fingers and I'll try contact wit my friend who swaped engine for me.
Thx alot
Raf
