I'm guessing either the boot seal's gone or something else but I'm not sure what.
Is there anyway to find the leak?
2 other issues as well, one the handbrake light doesn't work all the time, it comes on when you start the car, but turns off when you put the key into position 2 (ignition on). And the stereo doesn't hold its memory, I had to wire in a ISO plug after the previous owner had Halfrauds 'install' a headunit that I've since removed and replaced. Any ideas?
