Basic cold starting is still a lot better, but I'm still getting the following symptoms:
- Poor cold starting if it's been raining
- Really rough idle once started while cold (much smoother once warm)
- Exhaust often smells of petrol during cold idle
- Exhaust sometimes smells of petrol even during warm idle, after a drive
- Very unhappy to cruise along in gear at lowish revs without throttle - when most cars would just gently engine brake, it starts to kangaroo
- When I press the thottle from idle, it struggles momentarily, before picking up the revs
- Generally quite poor low-down torque, and unhappy low down - needs a lot more revs than I'd expect to move off
- Poorer MPG than I'd like - ~24mpg mixed, ~27-8 on longer steady journeys
I'll try and take it for a slower drive with the wide-band attached this weekend, and see what this shows lower down. In the meantime... any ideas?
