325i sport fuel gauge
nev325isport
Post Fri Jan 26, 2007 6:49 pm
im still having problems with my fuel gauge ive changed both sender units still no joy the bigger one improved things but only for an hour any ideas what else it could be?
marty1979
Post Fri Jan 26, 2007 6:57 pm
Hey man, exactly what trouble are you having again?
nev325isport
Post Fri Jan 26, 2007 7:15 pm
the fuel gauge gets to around half then falls to reservein the space of 5 minutes.
marty1979
Post Fri Jan 26, 2007 7:22 pm
Hmmm, have you checked the wiring from the sender to the gauge? There may be an intermittent fault between the two? Or maybe it's the gauge itself, when my temp gauge was playing up I found that the nut that holds the gauge onto the board was mega loose, all I had to do was clean up the connection and tighten the nut up. Maybe that's the case, or have you tried this already?
nev325isport
Post Fri Jan 26, 2007 7:34 pm
ive had the fuel gauge out of the dash and it all seems fine.might be the wiring but it isnt intermitant really.
marty1979
Post Fri Jan 26, 2007 7:38 pm
That is strange. The only other thing I can think of is that the board itself is playing up? I know that the batteries in the instrument cluster can go bad and leak, causing all sorts of problems. Give Brianmoore a shout, he'll no doubt know what's going on, he usually does. Sorry I can't help you out my man.
nev325isport
Post Fri Jan 26, 2007 7:41 pm
cheers anyway mate :cool:
nev325isport
Post Fri Jan 26, 2007 9:08 pm
just been out to the car it has motometer gauges should it have vdo?its an 89 sport. im probably clutching at straws! :mad:
Post Fri Jan 26, 2007 9:26 pm
Motometer and VDO gauges, and their component parts are all interchangeable, so that's not the problem. Don't know what is though - very strange fault description.
I suggest you short together the wires to each level sensor in turn, and run the car like that for a while, to see if the gauge, while reading wrong, at least becomes stable.
nev325isport
Post Fri Jan 26, 2007 9:48 pm
i changed the sensor on the left yesterday and that lasted an hour before the gauge sank to empty from half again and the obc range went down. ill recheck the back of the gauge tommorrow for tightness. is there any difference betwwen the 50 litre gauge and 60 litre gauge could it have had a 50 litre gauge and clocks fitted at some point?
Post Fri Jan 26, 2007 10:05 pm
The only difference is that the single level sensor tank set up uses a different gauge than the dual sensor tanks.(Not all E30s have a level sender under the round inspection cover).
nev325isport
Post Fri Jan 26, 2007 10:11 pm
so could one of the previous owners fitted the wrong gauge?
Post Fri Jan 26, 2007 10:17 pm
They might have - if the car has always been like this while you've had it.
If so, simply short out the sender under the round cover, and see if that improves things.
nev325isport
Post Fri Jan 26, 2007 10:20 pm
just tried that the gauge goes to just above half? :?
Post Fri Jan 26, 2007 10:26 pm
nev325isport wrote:just tried that the gauge goes to just above half? :?
And do you have half a tank of fuel?
nev325isport
Post Fri Jan 26, 2007 10:34 pm
around that i think!
Post Fri Jan 26, 2007 10:46 pm
Run the car like this and see if the gauge makes more sense.
nev325isport
Post Fri Jan 26, 2007 10:54 pm
ok mate! cheers for putting up with the stupid questions. :mad:
nev325isport
Post Sat Jan 27, 2007 3:54 pm
ive taken the car out this morning and the gauge hasnt moved off half in fifty miles so i lifted the sender up out of the tank and there is only a small amount of fuel in the tank. so linking the sender out hasnt worked. :x if i position both senders to read at a quater of a tank the gauge stays there.i cant understand whats going wrong?
