What size Torx wrench do I need to remove a Tourer rear bumper? Is there a cheat?
Or will the torx bolts be too rusty to undo?
Andy
What size Torx wrench do I need for Tourer Bumper?
Dan318-is
T55 nothing else will do it believe me i've tried!
andyborris
This sounds like a man who's tried and has the skinned knuckles to prove it!Dan318-is wrote:T55 nothing else will do it believe me i've tried!
Is it a real pig of a job?
Should I sell my Tourer and buy one with a tow bar already fitted?
stuartgallafant
andyborris
I had a look and couldn't see obvious bolts/nuts for the bumper brackets, I'll have another look.
Resigned myself to hiring a van, 'cos this towbar isn't going onto the car anytime soon, I've got to redesign and remake it first!
And
And
stuartgallafant
only one nut is inside the boot in the battery tray.stuartgallafant wrote:is it not like the saloon bumper where you can remove the 13mm nuts that hold the bumper carriers to the body. these bolts are located underneath the rear of the car and inside the boot on saloons...
much easier than undoing that torx bolt
WD40 is your friend here. Trust me it's a pig trying to get those 13mm nuts off. Easier to remove the big bolts with a T55 or 10mm allen key head. Theres 2 types of bumper bolts
Chris-W
