Story so far
powelly
Post Fri Jan 26, 2007 11:18 am
Yesterday after clearing my shed out I finally got the new battery on the BMW, reluctantly it started and for a moment didnt want to idle, once it had been running a couple of mins I took it for a quick spin round the block, it goes and stops, thats about it, definatley needs some TLC, I'm going to take a trip to ECP later on and get some service bits and then drop it to a body shop round the corner where he will repair the reust hole near the wiper spindle. I also found the pipe from the airbox to the throttle body was perished, this probably won't help the idling, whilst on the subject is the idle control valve known for problems, in the car were 3 others, all used.
More Later!!!!!
Image Le Mans Classic 2006
Templ8e30
Post Fri Jan 26, 2007 9:41 pm
The ICV can be prone to trouble (if it buzzes with the ignition on it's usually ok), the split boot certainly won't help.
You'll also find that when the battery is disconnected or runs flat the ECU has to re-learn the idle speed, this can take a few days.
What model do you have ?
Cheers,
Iain T
2007 Mazda 6 2.0 estate
powelly
Post Sat Jan 27, 2007 12:16 pm
I have a 1989 325i, the ECU thing would explain alot actually, I have been disconnecting the battery as the service lights stay on permanentley, this is something else I need to sort, after I left it running for a bit yesterday and took t round the block a few time it actulally sorted it's self out and the apparent misfire all but dissapeared.
I have a whole list if things I have found wrong, chief of which is the fact that the fuel guage, temp guage and rev counter don't work, does anyone have any idea what could cause this, all fuses are intact.
Dr Firefly
E30 Zone Doctor
E30 Zone Doctor
Post Sat Jan 27, 2007 12:34 pm
Lack of a working rev counter along with the service lights on probably means the SI board batteries have died - they go sooner or later on pretty much all E30s. Is your MPG gauge along the bottom of the rev counter working?
If you need to change the SI board or the batteries, this is a good place to start.
http://e30m3performance.com/maintenance ... _Board.htm
I didn't bother changing the whole board - desoldered the batteries and soldered in new ones - the batteries cost £6, as opposed to the board that costs £70 from a dealer.
Hope that's some use,
Ian
Templ8e30
Post Sat Jan 27, 2007 2:34 pm
Yep, Service Indicator board is prime suspect.
Put a wanted ad up and you'll probably get a few offers.
In fact I've got one of the later replacement types with the lithium batteries around somewhere.
Cheers,
Iain T
powelly
Post Sat Jan 27, 2007 2:38 pm
Ah, I asked a question about the service lights and was told the batteries had gone, didn't realise it affected the guages too, the MPG display is also not working. Atleast it's a straightforward repair.
Post Sat Jan 27, 2007 2:43 pm
Ideally, following battery/ECU disconnection, you should let the engine idle for at least 10 minutes, switch off, then restart and go for a drive to let the ECU relearn the settings.
powelly
Post Mon Jan 29, 2007 3:05 pm
Great stuff cheers, have put an ad on the wanted section for a new dash display.
Something else I noticed on my little jaunt around the block was a droning noise increasing in pitch as you get faster, at first I was thinking the diff was shot but after a little more thought, I think perhaps wheel bearings or prop UJ, do you think i`m barking up the wrong tree????
