When I start the car from cold and drive off in first and second gear the car squeels like a belt is slipping. Once car heats up a tiny bit it stops! Any idea's and how easy is this to sort!??!
I have a 1986 M10 318i.
Cheers!
slipping belt?!?!
RugbySteve
jcjdavis1
Hi when it is squeeling do you have heaters full blast,all lights on,rear heated screen on and radio on,maybe you need to check alternator belt is not slack.
march109
could also be PAS belt.
is it just when its cold or when its damp out?
carpmart
100% that this is due to a slack belt. the reason it stops when warm is friction kicks in and the belt grips the pulleys a bit better hence the noise stops!
RugbySteve
Def not PAS as car has manual rack!!
And yes car makles noise when lights / radio / heater on !! So if I check the Alternator belt how easy is it to tighten??
Chris-W
FBF
yep its your alternator belt. its a peice of piss.
im so sexy justin brought me back 5 times
Check the belt for condition to see if it needs replacing, and don't over tighten it, or you'll cause worse problems.
