Non starter.
grantfk10
Post Thu Jan 25, 2007 3:36 pm
Hi folks, I got a problem.... I went to take the cab out of the garage, and it wouldn't start. Ok, it's been hibernating over December/January, so I thought it might just be a flat battery. I got it started first time with jump-leads and took it for a bit of a run to charge up. After returning, I switched off and now it won't start. The warning lights come on and the headlights are shining. Is it the starter? And how do I go about sorting it out?
Any help appreciated.
marty1979
Post Thu Jan 25, 2007 3:59 pm
It could be the starter solanoid, or it could be something as simple as the battery terminals being cacked up or loose. I moved my car off the drive a couple of weeks back, parked it on the pavement for 5 mins, came back to it and it wouldn't start. I cleaned up the battery terminals and that sorted it, hasn't happend since. It could also mean that the battery is completely trashed and won't hold charge any more?
carpmart
Post Thu Jan 25, 2007 6:39 pm
I agree with above, battery likely to be screwed and not holding charge or bad connection as per Marty post!
Chris-W
Post Thu Jan 25, 2007 6:40 pm
Battery's died. Probably holding enough to light up the instruments, but that's about it.
320Touring
Post Thu Jan 25, 2007 6:42 pm
Chris-W wrote:Battery's died. Probably holding enough to light up the instruments, but that's about it.
Agreed. similar situ with my touring at the moment :cry:
grantfk10
Post Thu Jan 25, 2007 10:13 pm
Cheers for the help guys, looks like I'll be getting a new battery at the week-end then.........
