Ran out of window washer fluid few days ago, topped up yesterday and noticed that barely anything was coming out of the jets, just leaking, no pressure. To be honest the pressure was weak since I bought the car few weeks ago, but this was pretty much dead. Lifted the bonnet and realized why - when activated the washing fluid comes out from the T-shaped plastic thingy that joins some hoses at the top (when open) side of the bonnet.
What's the purpose of the valve? I took it out (not much effort required), washed, tried blowing trough it and it doesn't seem to let any air trough, except when blowing trough the bottom part of the valve.
What are the two holes on one side of the valve, seem to be some sort of overpressure protection? I have a sneaking suspicion this is where the fluid comes out, does that mean I have to clean the washer jets?
Any information/ideas/tips would be appreciated, would love to get is sorted out today, it's annoying to have dirty windscreen.
Window washer problem
casper8r
Washed the thingy (yeah, like that helps a lot!), put it back, cleaned the washer jets as good as I could - still no joy, the water simply squirts out from the tiny holes in the plastic thingy. Of course I could just go to the dealer and buy the whole tube set... only to find out it was something else?
sam325is
try a another black motor for your washer bottle.if the jets have been weak since you bought the car its a good chance the black motor is getting tired. This would mean it wouldnt be able to send fluid through at a high enough pressure.
E30Mark
Glue up the holes in the *thingy*
PM for details
PM for details
casper8r
Well... it doesn't compute - how come it's strong enough to squirt the liquid out the plastic valve (or whatever that thing is), and the pressure is good, but not trough the jets? I suspect the plastic t-shaped thing with three pipes going into it has some sort of pressure release and that engages because something else is blocking the flow of water. Either that, or the plastic thing is broken.
Man, I wish it was computers, that I can handle, but as soon as its mechanics...
Andy335Touring
Generally i've found when the washer jets get clogged it pisses out of the one way valve, clean the jets out with a pin and it's sorts it's self out.
marty1979
Or if you have access to an air compressor try blowing the crap outclean the jets out with a pin and it's sorts it's self out.
marty1979
Gwynleym10
The T-piece valve cost about £4 from ECP. Sorted my issue out.
I had this issue with mine last week, prior to the MOT. I replaced the right-hand 'thingy' for a straight-thru T-piece which sorted it, both for normal and intensive wash.
I tried blocking up the holes on the old leaking 'thingy' with insulation tape; it halts the flow completely!
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Throw the valve "thingy" in the bin where it belongs. That's what I did and fitted a non valve "thingy" instead. Not had any problems with my "thingy" since.
Taylor.
Taylor.
Internal failure of these valves/tee pieces is not uncommon.
The cure is simple enough - replace with a new one from BMW! They're cheap enough.
sam325is
[quote="casper8r"]Well... it doesn't compute - how come it's strong enough to squirt the liquid out the plastic valve (or whatever that thing is), and the pressure is good, but not trough the jets?
dont glue up the holes as they should be there,i THINK they are breathers not 100% sure tho. as for the job of the valve they are one way valves, they make the flow of water go forward only never backward....this means that as water cant travel back there is always water at the jet, this means that when you operate the screenwash function water sprays straight out with no delay as water is directly behind the jet. if you remove the valves you will get a slight delay before water comes out of the jet as the water would be able to run back a bit. however if you have reassembled this system before you should note that the non return valves need to be the right way round
The thing is that the hole in the washer jets is pin prick thin and the size of the hose and t-pieces and non-return valves are all big so in theory your pressure could be too weak to push water out through the jets at a high enough pressure.
blockages in these systems arent too comon as the washer bottle has a lid on it and in theory there shouldnt be anything going in to the bottle but water so it shouldnt get blocked.
it may be blocked if someone has loaded it up with loads of screenwash before, used it a few times and then not used it for a long time giving the almost pure screenwash time to dry out and crystalise.
do you have the clear or black washer tubes? if you have the clear tubes blockages should be visible. run water through the T pieces and non return valves to see if they are ok. as for the washer jets get some water in your mouth get a washer jet put the hose end in your mouth and try and force water in your mouth through the jet...this will then narrow down what it is. if there is no problems with the above then its your black motor on your washer bottle.
do you have headlamp wash/wipe on your car?
