LSD Oil...Which One????
Pal318is
Post Tue Jan 23, 2007 7:25 pm
Guys, i will have aquired a 4.10 lsd for my iS by next week winkeye
What the best diff oil to use in it? before I put it on...
It's not going straight on, as I want to put it on at the same time as dropping the new engine in there.
Phanks
Pal
Pal
Image[img]http://Image
garyp_E30_325i
Post Tue Jan 23, 2007 7:32 pm
Book I have quotes: "SAE90 hypoid gear oil" that's for a 325i Sport with 3.91 LSD (I'm about to fit one myself, so I'm interested to see if anyone else recommends something different)
'89 325i - was an SE but not anymore, was bronze-beige metallic (yeuch!) but now techno-violet (thankfully)
'89 Toyota Corolla GTi-16 - track, hillclimb & sprint car (yeeha!)
'08 Buell XB12Ss - American engineering at it's 'best'... good fun though
gcorky
Boost Junkie
Post Tue Jan 23, 2007 9:47 pm
sturaco needs adding such as castrol saf i believe ,lsd oil requires this addative...not straight 90
525 sport
gcorky
Boost Junkie
Post Tue Jan 23, 2007 9:50 pm
Oils for standard (open) diffs:
BMW Synthetic OSP
Castrol SAF-XO
Oils for Limited Slip diffs:
BMW Synthetic MSP
Castrol SAF-XLS
[unknown brand] VS-700
( Note: There is a GM additive "Goodwrench Limited Slip Differential Additive "
#1052358, that is popular with some BMW Dealerships. It's cheap and
can fix some LSD noises when combined with standard gear oil. Ed. )
525 sport
stuartgallafant
Post Tue Jan 23, 2007 10:29 pm
pal, BMW dealerships use Castrol SAF-XJ for the LSD's
if you go into a dealership, its about £15 a litre +VAT, but you cant buy it like that! they have to carry out the work for you to have the oil!!!
however, if you tell me if its a large case or a small case, I might just be able to help you out, if you know what i mean??? winkeye
WillG
Post Wed Jan 24, 2007 12:26 am
they sell it to my bro at cotswold BMW, with discount
Pal318is
Post Wed Jan 24, 2007 12:37 am
Cheers for all the info Guys, much appreciated as always!!
stuartgallafant wrote:pal, BMW dealerships use Castrol SAF-XJ for the LSD's
Stu, will find out wether it is a small or large case, and also see if I can get it from my dealers, as I have a mate who works there, if you know what I mean winkeye
If I have no joy, then I shall give you a shout..
Can't believe i'm finally getting one :D
Top Man
Pal
Pal
cliffybabe
Powered by Nelly
Powered by Nelly
Post Wed Jan 24, 2007 12:49 am
Pal, stu is the man when it comes to slipper oil and gaskets winkeye remember all teh fun u have with mine stu :o:
Pal318is
Post Wed Jan 24, 2007 9:36 am
cliffybabe wrote:Pal, stu is the man when it comes to slipper oil and gaskets winkeye remember all teh fun u have with mine stu :o:
I don't think I wanna know :mad:
Will give Stu a shout, if I can't sort anything down here
Pal
Pal
stuartgallafant
Post Wed Jan 24, 2007 10:20 am
pal, it should be a small case, in which case it will need 1.0 litre dead on
large case needs 1.7l
hth
