is there anything else i may as well get/replace seeing as she'll be up in the air for a couple of days on my E30 325i cab?
So far on my list is track control arms, track rod ends and steering rack boots anything else I missed?
thanks in advance
changing track rod ends and track control arms
eko
- Old timer
Drop links,anti roll bar bushes?
May as well do the lot?
- **BANNED**
Control arm bushes.
Royalratch
Not really 'in the air' job but engine mounts and gearbox mounts can make a difference too...
Will drive like a new car after all that lot...
glenbat
cheers again guys
she's going up in the air this weekend, are there any specialised tools I'll need apart from the usual spanners, sockets etc? I'm working thurs and fri so can borrow anything I may need from work
eko
- Old timer
Decent ball joint splitter will come in very handy!
Not the shitty fork type
Control arm bushes ideally need a press or large vice to push them into the lollipops.
Alyman
If you're gonna be doing the work on friday, I'd think about coating a few of the bolts etc in WD40 a couple of times over the next couple of days.
Some people would recommend having a ball joint separater for the control arms, but you can also use a hammer if you're going to be replacing the control arms anyway!
You should have some copper grease handy for the middle balljoint on the control arm - also make sure sure you stock up on patience - mine ran out when I was doing the control arm on the drivers side (the middle bolt on the driver's side control arm is really hard to get to because of all the steering gear thats in the way!).
I let a garage do that side in the end (I suspect that if you had enough extensions for your ratchet, this job could be done more easily from above, but don't quote me on that, it's just a theory!)
Everything else was quite straightforward though
Good luck
Good luck
eko
- Old timer
As Alyman said,loads of extensions and the middle nut is easy,maybe a socket knuckle joint too!
glenbat
need a bit of advice lads, the arm that screws into the steering rack (uses 32mm spanner) is pretty fooked any suggestions as to getting it off?
