MOT 1 - E30 0 :(
Jos
Post Mon Jan 22, 2007 2:27 pm
Just been pwned by the MOT centre lol..
Well it wasn't that bad really, failed me on my front springs (they fell out when he put the car on the lift (Northern Ireland MOT2 btw))
Told me basically the spring type is wrong for the car, and he is probably right actually but hey. So I need a new suspension setup for the car but there is a twist :)
With the planned M30 engine swap which increases the weight on the front axle the height at the front becomes an issue.
M40 - 81kg
M20 - 117kg
M30 - 143kg
So the question is which kit, there is onlly a kit for the 325i Touring in 60/40 from H&R. KW seem to have a larger range but how do they compare to the H&R setup?
Or the other option is to get a KW set that match the car at the moment then worry about what to get after the swap?
Suggestions?
'94 e36 tree climber
Martinaston
Post Mon Jan 22, 2007 2:59 pm
Nothing wrong with the springs, your shocks are too long.
There is NO nucleus.
Jos
Post Mon Jan 22, 2007 4:26 pm
yeah, but they are also the springs off a saloon so the ride height is all over the shop anyway. Itchy creditcard here so what should I buy!!! :)
