Got my E30 325i at the weekend and its got annoying little problem with the fuel gauge, it doesn't work!
Its stuck on full all the time but after driving for about 15-20mins it kicks in and works normally.
Any ideas?
Got a feeling it could be a sender unit but how easy are these to replace and get hold of?
Fuel Gauge
Chris-W
Dannyboyb
Cheers mate, just what i wanted to hear, had horrible visions of having t drop the tank or something stupid to get to it.
Thanks for the offer gonna clean up the one i've got first to see if that works, if not i might need that one.
Chris-W
Greeny
I had the same problem with mine but only after i'd had the clock's apart to fit a carbon surround. What had happened was for some reason the fuel gauge had come loose from the circuit board and just needed tightening up and the conections where the gauge pins fit in cleaning up.
So if the sender doesn't work check the actual gauge itself.
Gone but not forgotten.
('92 325i Cabriolet)
May be a second sender under the left hand round inspection cover as well.
