Leaky sunrrof - Window removal etc
GBE30
Post Mon Jan 22, 2007 1:19 pm
Hi all,
I have currently got a leak which I believe to be the sunroof which eventually creates a paddling pool of wonder in my rear drivers footwell.
I know this could be a rusty tray etc but being me I have to find out for sure. Is it easy to remove/replace the rear screen and quarter window/s?
Any tips?
Bored of changing my towel under the carpet!!!!!
Gareth
kevin316i
Post Mon Jan 22, 2007 2:20 pm
Are you sure it is the sunroof? The sunroof seal itself is not watertight, it is depending on the drains to get rid of any water that seeps in past the seals. Before dismantling anything, check that these drains are clear.
Also check the sill drains, as if they are blocked, then water can back up in the sills and overspill into the footwells. Also check if the front foot well is wet or not. If water was seeping into the front footwell, it could eventually reach the back one. The problem with water under the carpet in the front footwells is that it can soak up water for ages before it makes its presence known.
GBE30
Post Mon Jan 22, 2007 2:37 pm
I am pretty certain as I have soaked up water. Then I poured water into sunroof both sides and I can see it run into boot by the rear shocks and disapper toward the front of the car!
I have tried poking some wire up the tubes and it certainly does not come out at the other end and visa versa so on and so forth!
kevin316i
Post Mon Jan 22, 2007 5:24 pm
Sunroof drain tubes exit at both sides in the boot through a small oval shaped panel down in the recess behind each wheelwell. If you can remove the end of the drain tube here, you could try pushing a wire from here upwards towards the sunroof. When pushing the wire from the sunroof end of the pipe, there is a slight possibility that the drain pipe might become detached at the sunroof. As the pipe is plastic, then any leak would be due to either an overflow the sunroof area due to a blocked drain or a detached drain tube.
