quicker steering idea...
gareth
Post Sun Jan 21, 2007 10:50 pm
i had an idea earlier...
on MK1 / MK2 escorts, the steering arms (on some struts) are detachable from the strut and shorter ones can be fitted. this gives a higer ratio on the strut while keeping the rack the same
i was thinking this would be easier than wrestling a E36 one in amongst my M30 downpipes as there are clearance issues as it is! the other options for a quickrack involve fitting a non pas rack and a quickrack kit which i can only imagine as being fairly heavy with a M30!!! i had a 2.4 turn quickrack on my RS2000 and that was a high ratio but in a much lighter car
as the steering arms on the E30 struts are integral this obviously makes life harder but with some proper engineering i think it could be done well...
the main issue i can see is that of messing up the geometry a bit as the track rods will face a little more rearwards and fitting the offset M3 bushes i have will only compound this
any ideas?
