Funny electric whine
willow
Post Sun Apr 03, 2005 9:08 am
Okay, so I went to pick up my Mtech 2 door pods and skirts yesterday 8)
It was a good 130 mile round trip. I noticed on the way down that I could here an electric sounding whine that was coming from behind me. The noise continues when the car is idling. If I turned the engine off for a few minutes then turned it back on, the electric whine would not reappear straight away, but would start again after a few minutes 8O
So, any ideas? I have a feeling it's the fuel pump - what do you reckon?
Cheers!
Save the E30s!
jitvv
Post Sun Apr 03, 2005 9:09 am
agree sounds like fuel pump
willow
Post Sun Apr 03, 2005 9:11 am
okay - so is this difficult to change?
Save the E30s!
Geeman
Post Sun Apr 03, 2005 10:00 am
Fuel pump. Mine does this everynow and again... since I fitted the new fuel tank... Grrrr! Sometimes it gets quite loud. Had a chap tell me I can hear it because the new tank doesn't have the sound deadening put on from the old tank... those spongey things round the sides... Whoops!
Not sure how it fits, but I'm pretty sure it just 'pops' in from the top, underneath the back seat. Might be worth investigating.
jitvv
No, very easy to change, disconnect the battery, take the back seat base out. you'll see on the drivers side a round cover which i think is held on with 3 screws undo them then you'll see the top of the fuel pump. unclip the wires and pull them aside. Then undo the clip holding the fuel line on. (you properly want to do this once the car has been sitting overnight so the fuel pressure is low, otherwise fuel night go everywhere) once fuel line is off twist the whole top of the fuel pump anti clockwise this can be hard if its never been taken off before and slowly slide the pump out. and as the haynes manual says do the reverse to refit the fuel pump. Hope that helps. might want something to soak up the fuel as a little did spill when i changed mine.
Jit
willow
Post Sun Apr 03, 2005 10:21 am
Cheers chaps, I'll give it a go once my car's back from the body shop - goes in Monday 8)
Just looked on GSF site, I'm guessing it's this one I need right?
"FUEL PUMP-IN TANK BOSCH " or is it "FUEL PUMP+PICK UP ASSEMB." - maybe either will do but apparantly the first one is an original replacement.
Ciara
Save the E30s!
jitvv - You missed something important. You can't get the fuel pump out unless you remove the fuel gauge sender first. Four small nuts on the top of the pump assembly, then pull straight up.
To get rid of the fuel pressure, pull out the fuel pump fuse and start the engine and run it till it dies.
jitvv
Post Sun Apr 03, 2005 10:25 am
doh, I did change this a while ago i thought i missed something out. nice one Brain :D
Templ8e30
Post Sun Apr 03, 2005 10:35 am
Hi, iirc the first part "FUEL PUMP-IN TANK BOSCH " is just the pump and needs soldering to the rest of the unit and the second part "FUEL PUMP+PICK UP ASSEMB." is the complete new assembly.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
willow
Post Sun Apr 03, 2005 10:48 am
Cheers Templ8e30,
I'll get the second one then, save myself a job.
Ciara
Save the E30s!
325ic
Post Thu Apr 07, 2005 5:58 pm
I have the same problem after my knackered BMW tank with was replaced with a GSF one. When you save Ԛ£400 or whatever it is a pretty clean cut case.... However this noise makes me believe for a moment that I am driving a C5 at times and being a cabrio you can certainly hear it.
Just to clarify if I get a new OEM "FUEL PUMP+PICK UP ASSEMB." will this be quieter than what I have now or is there some sound deadening missing off the actual tank itself, and if so where do I get it from and is it easy to fit or does the tank need to come back off again?
Post Thu Apr 07, 2005 6:40 pm
There is no sound insulation on the standard petrol tank.
It's bolted to the car body by rubber grommets, and the actual fuel pump sits in rubber mounts on it's fixing frame.
Replacement versions of both should be the same.
Adammcf
Post Thu Apr 07, 2005 6:42 pm
Before you change the pump try changing the filter.
If its dirty it will make the pump have to work harder and it will be louder.
I had the same problem in my GSI Astra. New filter and it was silent again.
