First post - but not a happy one. help please.
leslie
firstly hi to all fellow zoners. I acquired a rather nice 325i touring just before Christmas - very pleased with it I am too. however last night a lowlife took a fancy to my radio. result - smashed rear quarterlight glass and drivers side lock well buggered with a screwdriver also causing damage to door. only consolation is that the little turd didn't manage to get the radio away. anyway it strikes me that it might be easier to source a 2nd hand door than just the quarter light, question is how easy/diificult would it be to get the glass out in one piece and replace into my door. second question, i have the door card off but there seems to be no easy access to the rear of the cylinder lock to pull off retainer and so remove old cylinder - any ideas? thanks in avance.
Whenever I need to remove a lock barrel I always take the window mechanism out, you can swing it to one side but its only 5 mins to take the thing out, it will give you much more room and you will be able to see what is going on in there.
The lower part of the window glass guide that gets in the way is in two parts. If you undo the single bolt that holds the bottom of the guide and pull the metal part of the guide downwards a little, letting the felt/rubber part of the guide slide inside the metal, then it will unclip just below the level of the bottom of the glass.
Swing the bottom of the channel forwards and upwards and hang it on the winder mechanism.
Take care to engage the clip properly when you refit.
