do you need to change the ecu.
iggy-rs
Post Sat Jan 20, 2007 7:10 pm
when you change an engine or will it work with the original ecu..
i have heard different stories and just wanna check, cheers in advance
Andy335Touring
Post Sat Jan 20, 2007 7:19 pm
It depends what engines you are swapping ?
I think you can get away with just a chip change if you are swapping from a 2.0l M20 to a 2.5l ?
Thats assuming your using the same version/age of Motronic ECU.
snoops
Major Helmet
Post Sat Jan 20, 2007 8:44 pm
yeh some of the old engines r jetronic
iggy-rs
Post Sun Jan 21, 2007 8:28 pm
it would be another 325 lump, same as whats in there....the ecu is there as well, so no huge dramas....
E30Adam
Post Sun Jan 21, 2007 8:31 pm
Same one will be fine mate!
Bear in mind it will lose it's memory after being unplugged for a while when you're changing the engine so might run a bid lumpy for a while. Just take for a nice drive so it can relearn then settings and you'll be fine.
