Aluminium wishbones (control arms) cracking?
john325tewerin
Post Sat Jan 20, 2007 2:39 pm
Hi fellas.
I've got a sneaky feeling the n/s aluminium wishbone on my Touring has what looks like a hairline crack or two near the centre balljoint. Are they known for this? Does anybody have any experience of ally arms cracking on them? Is there a way to test them ie. xray or ultra-sound.
I get the feeling that I'm probably gonna have to play safe rather than sorry and bin it. Imagine a control arm snapping at speed :clin:
Post Sat Jan 20, 2007 11:42 pm
I've heard that cracking isn't unknown, although rare. Should be able to test them with a special dye that will be drawn into the crack by capillary action.
kam-325i
Post Sun Jan 21, 2007 12:04 am
A simple test we use at work to check for cracks is to tap the item, if you get a nice "bright" ring/ding, it should be ok, if you get a kinda thud/donk.....suspect a crack.....
Another way is to use a "thin" liquid, like thinners or petrol.....put some arond the area you think may be cracked, leave it for about 10 mins, then wipe clean and use some talc on the area, 90% of the time a wet line will appear indicating a crack.....
These methods are not 100% thou.......
k
Post Sun Jan 21, 2007 10:27 am
If you know anybody that works at a small/medium engineering fabricators works, they will have access to the 3 cans of fluid you need.
Cleaner...dye....developer. You can buy these aerosols from engineering suppliers and it's not rocket science to use them. Don't just scrap it without checking, as castings/forgings can have marks that look like cracks but in fact aren't.
john325tewerin
Post Sun Jan 21, 2007 12:27 pm
k wrote: Don't just scrap it without checking, as castings/forgings can have marks that look like cracks but in fact aren't.
That was my thinking too. I've lightly rubbed the area with some fine emery to try and ascertain if is simply surface casting. Not sure if all I've done is just made the crack less obvious!
Thanks fellas I'll try dying the area and see what shows up. Cheers.
