early cab fuel pump
MARTYCAB
Post Fri Jan 19, 2007 10:16 pm
hi there people just after a little help to solve a little problem i have just got myself a 87 cab as a run about. when we got it problems occurd on the fuel system i have fitted a new external fuel pump the transfer pump in the tank is the one i now have a problem with. i need help in understanding how it works . because as you drive the car somtimes it will try to cut out or drive at very low revs like a starvation of fuel if you get out and bang the tank it will run again or turn the key off and on very quick as you are driving it then runs ok so please try and answer any help would be great thanks
Post Fri Jan 19, 2007 11:26 pm
Not really sure what your question is, but your transfer pump is dud and needs to be replaced. This could well be what killed the first external pump.
An E30 will start and run with a dead transfer pump, bur will suffer fuel starvation when the engine is under load.
A better solution to replacing the transfer pump is to fit a later in tank pump (fits straight in), and remove the external pump and its wiring completely by modifying the loom under the back seat and connecting the inlet and outlet pipes of the pump together.
MARTYCAB
Post Fri Jan 19, 2007 11:48 pm
thanks mate reading back what i wrote i did wonder what the ? was .I have a new in tank pump in the shed do you know whats involed in the wiring please for me to fit it thanks for your time
Post Fri Jan 19, 2007 11:56 pm
I've done this before myself, but can't really remember if the connector is the same.
The same wires that supply the transfer pump can supply the later in tank pump (green/purple and brown), and if the connector is the same then it just pushes on. If they are different, then a different connector will need to be spliced on.
The old wires to the pressure pump can be drawn back into the car, and the green/purple either insulated or removed at its join to the main loom.
