sunroof removal easy?
Padzer
Post Thu Jan 18, 2007 3:08 pm
I have rust bubling through my sunroon (manual wind on a 320 touring). The tilt function is working but the fully-open function seems to be stuck. I have purchased a sunroof in better condition but was wondering if this is a job I should take on myself or hand over to a garage?
Theo
Post Thu Jan 18, 2007 3:42 pm
It's fairly straight forward. Wind back the roof a bit - pull down the fabric trim panel - its secured by 6 spring clips that just pull out. Then wind the roof forward and up into the tilt position - now you can pull this panel clear and will be able to see the 6 star shaped screws holding the metal panel in place, remove these and it's off.
Post Thu Jan 18, 2007 7:30 pm
Theo325 wrote:It's fairly straight forward. Wind back the roof a bit - pull down the fabric trim panel - its secured by 6 spring clips that just pull out. .
Then slide the trim panel right back out of the way.
First thing you'll have to do is get the sliding mechanism working. This will just be hard grease on the runners.
Get some WD40 in there and work the roof back and over again a little at a time, giving it some direct assistance by hand until it comes free.
oze30
Post Fri Jan 19, 2007 4:05 am
Just watch out.. it was a buggar to get my lining back onto the roof panel..
mybmw6
Post Fri Jan 19, 2007 8:30 am
Brianmoooore wrote:Then slide the trim panel right back out of the way.
Can this trim panel be removed from the car or is it stuck in the sun roof mechanism (I want to get mine retrimed, its looking a bit tired).
Chris-W
Post Fri Jan 19, 2007 8:34 am
It can be removed, but is attached to the mechanism with a hinged arm on each side (with rivets, iirc) .
