Steering wheel removal
win
Post Thu Jan 18, 2007 11:08 am
does anyone know what size socket is use to remove the steering wheel?
Win
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Jan 18, 2007 11:09 am
off the top of my head i think its a 19mm
orangecurry
Post Thu Jan 18, 2007 11:18 am
my head-top says 22mm :mad:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Jan 18, 2007 11:19 am
i tried its early :roll:
Pal318is
Post Thu Jan 18, 2007 11:20 am
I think it's bigger than a 19" Neil, pretty sure it's either a 21 or 22"
Pal
Pal
Image[img]http://Image
Ziggy
Post Thu Jan 18, 2007 11:24 am
22mm. Mr Curry gets the prize!
Pal318is
Post Thu Jan 18, 2007 11:26 am
:rock: :cheers: :clap:
Get in there curry!!
Pal
Pal
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Jan 18, 2007 11:28 am
Ziggy wrote:22mm. Mr Curry gets the prize!
nooooooooo :cry: :cry:
SPADGE
Post Thu Jan 18, 2007 11:30 am
Yep 22mm
Don't forget to put the key in the ignition on the 1st click to release the steering lock or the wheel won't come off
orangecurry
Post Thu Jan 18, 2007 12:27 pm
I feel so special....
perhaps I should do something useful with my talent.
E30Mark
Post Thu Jan 18, 2007 12:31 pm
Don't also forget to leave the nut on a couple of turns, otherwise you risk knocking your front teeth it when you try to pull it off... once loose, remove the nut.
PM for details
dazleeds
old skool raver
old skool raver
Post Thu Jan 18, 2007 12:33 pm
E30Mark wrote:Don't also forget to leave the nut on a couple of turns, otherwise you risk knocking your front teeth it when you try to pull it off... once loose, remove the nut.
Beat me too it :D
www.oldskoolfantasy.co.uk
wildeian
Post Thu Jan 18, 2007 12:44 pm
...No matter how hard you pull it!!! :o:
win
Post Thu Jan 18, 2007 1:53 pm
Cheers guys the biggest socket i had was 21 did'nt realise it was that big
Win
SPADGE
Post Thu Jan 18, 2007 3:01 pm
Got to say that i have never had a problem pulling a steering wheel off very easily one the nut was removed and the ignition on.
Morat
Post Thu Jan 18, 2007 3:45 pm
I had a lot of fun, until I remembered about the ignition key.
ah well, nothing damaged but pride. I think I invented some new words too....
Theo
Post Thu Jan 18, 2007 3:48 pm
If you have one of those 4 socket wheel braces one will be the right size.
win
Post Thu Jan 18, 2007 5:21 pm
AH, I did'nt think of that, i've got one of those braces.
