From Euro style back to Stock
spence_star
Post Thu Jan 18, 2007 9:05 am
Guys,
I need a lil advice on my wipers. The last owner of my car had the euro conversion done as i think he had a single wiper which he then changed back to 2 wipers.
The annoying thing is that when i put my wipers on they stop randomly on my windscreen and not back to where they started from. So to turn them off and get them to the right place i have to switch them off manually at the starting point instead of the normal way.
What do i need to do to get it back to normal?
Is it the wiper motor?
Do i need to get a stock one?
Advice please..
ian332isport
Post Thu Jan 18, 2007 9:55 am
Just sounds like the parking switch is dirty. Have a look through the tech procedure for info on how to clean it.
http://www.e30zone.net/modules.php?name ... wipers.htm
Ian.
spence_star
Post Thu Jan 18, 2007 10:11 am
its wierd, mine done stutter, its like they have been set to stop wherever. The euro style way was to have a single wiper stationary in the middle of the windscreen. And i think this is what the last owner wanted.
Returned after many years out.
Post Thu Jan 18, 2007 10:25 am
If they always park in exactly the same place, then you need to move the arm on the wiper motor around on its splines.
Undo the nut, lever the arm off the tapered splines, move the wipers to the correct park position, put the arm back on the motor spindle and refit the nut.
spence_star
Post Thu Jan 18, 2007 11:10 am
ok i will give this ago, this might actually do it.
What i will do is let the wipers go up once until it stops in the middle of the windscreen, then do the undoing of the bolt and adjust the wipers to where it should park, bolt it up.
Hopefullyy this will solve it.
ian332isport
Post Thu Jan 18, 2007 11:14 am
You said in your original post that they stopped randomly on the windscreen. If this is the case, it's still propably a dirty park switch inside the motor. If it always stops in the same place then Brians method should work.
