after a rather embarrasing "konk out" on a 3 lane roundabout in the touring, It looks like my fuel light doesnt come on...
any ideas of how to test., or repair folks?
Fuel light not working?
320Touring
march109
I assume you've established if its a faulty bulb or not?
320Touring
nah mate was snowing- ie get petrol and get the bastid back home, then go to uni exammarch109 wrote:I assume you've established if its a faulty bulb or not?
march109
check that first or it could be alot of work for nothing!
wildeian
I'm not sure if mine is working either. Is there a quick test, or is it clocks out?
gcorky
- Boost Junkie
A lot of people claim they don't work, but they usually do. The needle on the gauge has to go right down past the complete red painted section of the gauge, and onto the part that lights up before it will come on.gcorky wrote:mine dont work either,bulb ok,petrol guage works but no low warning lamp.....
That said, it's an electrical circuit with no test function, and it has an incandescent bulb. Both can fail.
Easiest way to test it is to take out the rear seat cushion, and either short to earth the brown/grey wire at the connector tied to the fuel vent pipe on the RH side of the seat, or to remove the inspection hatch and short the wire to earth on the pump connector instead.
Fuel light should come on with ignition on.
orangecurry
Mr Brianmoooore sir - how much capacity have the 6-pot petrol tanks on PRE-facelift models please?
62 L
55 L
63 L
thanks!
62 L
55 L
63 L
thanks!
From the red covered handbook for facelift stuff:orangecurry wrote:Mr Brianmoooore sir - how much capacity have the 6-pot petrol tanks on PRE-facelift models please?
62 L
55 L
63 L
thanks!
55 litre - 316i, 318i, 318iS, 324d/td
62 litre - 318i touring, 320i, 325i, 325iX.
From the silver covered handbook (copyright 1987):
57 litre - 316, 316i, 318i, 324d/td
64 litre - 320i, 325i, 325iX.
Have a vague recolection that the 323i was something different again.
orangecurry
you've just made that up to make our brains explode...........
Skip
My old 316 went waaay under the red before the light came on but my 325 just dips under it and on it comes....
ex-325i Touring
