Death of a 2.7? help needed big styleeeee :(
liam012
Ok - sorry for melodramatic title but i really need your help - i am at the lowest i have been throughout the whole procect and i think it might be on its way to an end,
all along the way between missing parts, wrong parts, ripped off for parts, everything that could go wrong seemed to and now it seems the final blow may be on its way -
The immediate problem:
Yet another airlock today? wtf? OIL LIGHT is just coming on at idle, goes away with revvs. it doesnt come on immediately at idle either takes a minute or two then barely flickers on - this i happened i think due to the rise in pressure.
plenty of oil in car - no mayo no oil in water.
points to note - has been running a tad lean or the timing marginally out as it was pinking under load (so i didnt put it under load as much as possible to avoid damage) but today that was solved with 500ml of miller octane booster - pinking is barely still there but i had 55 litres of fuel in the tank and i only had enough booster for 20 litres so it seemed only a little octane helped the pinking considerably.
i am waiting till the car i cool to fill and bleed for the third time this week
i dont have access to compression testing equipment unitil friday
somebody PLEASE tell me it is possible for a pressurised sytem to cause an oil pressure problem at idle
or is it looking like loss of compreession?
Ant
- Retired Team Member
pinking will normally cause the H/G to fial 1st Liam.
Obv the above could cause loss of coolant
you are using the 2.7 specific chip I sent you right ??
ref the oil lamp, check the wiring to the sender again dude, bad connection being vibrated could be the main issue there.
no mayo is a good sign, how pressurised is the coolant dude ???????
need more info on the engine spec, bt from your previous post I'd say the C/R was a little too high, only because you stated that the pinking is under heavy load, but not @ any other time
Get the MS on there dude, soo much more flexable, plus you'll have live data on coolant temp as you drive, in real time
sending you positive vibes M8
O/T, you get the PM off Steve re design work ??
Email FTW
SPADGE
Are you sure the 'pinking' isn't the bottom end knocking?
Would answer why the oil light is coming on if its not a sensor fault.
Hope i'm wrong and good luck.
liam012
well - after a few hours in the cold cold rain, under and over the car beavering away in the hope that she will live...
and maybe she will
it seems there is something weird with the cooling system allright , the top two hoses dont want to stay bled? as in they get red hot and are full but a few mins later they feel empty - bleeding from the valve just isnt working that well so have taken to using the return pipe from the radiator to bleed em up and doing so really worked better than anything all week - the hoses got hotter than they ever have this week and the temp gauge instead of being at half way went down to the first notch before hand, it now after a 20 min idle a 10 min drive and another 10 min drive just stays marginally below half way - never over.
sourced some more octane booster so now i have the specified ammount of it for the ammount of fuel i have,
the pinking is next to gone , i really have to try to get it now so i wont try any more.
in saying that the car has never in the 1000 miles ive run it run as beautifully as it just did - the smoothness and refined feeling of the engine was just staggering - not as brutal as it has felt for the last 1000miles - it really was a silky pleasureable drive
as for the bloodyy oil light - it flickerd allright when i started the car at first then went away for good then went for a drive and started to come back when i was driving (it is always faint never strong) - i am crossing my fingers toes and ears that it is a bad earth as i can find no pattern to it coming on at all when driving the only thing i am thinking is the wetter the underside of the car is the more problematic the light is (and it first arosse when it started to rain today)
we live in hope....
and maybe she will
we live in hope....
BristolBulldog
liam012, totally off the subject, but it could distract you for a minute. your sig pic? is that from "gp1"? that game is ages old! would be amazed if its from that!
hope the cars still running.
liam012
yes its actually gp4 and because i have quite a high end pc it runs very very well high fps low cpu util and is the only game left on my pc but i never get a chance any more between work the young lad and a real car!
still keep it in the hope that i'll get a quiet winters night to myself to do 50 laps of monacco without crashing after spending hours tweaking the suspension/toe/ride height etc
and come last
them were the days
and come last
them were the days
BristolBulldog
remember when i first got into it. GP1. was it richard craymond? or something. Try getting it to run on xp now lol! it won't use ram thats how old, it runs out of "virtual memory". Those were the days lol.
Shame 3dfx is no more. remember power vr at all?
microprose has gone bust now hasn't it?
Check the small rubber hose from the top of the rad to the filler neck isn't blocked.
For the oil pressure light problem - the wire goes around the front of the engine, where it;s insulation can crack or get chaffed by the water pump pulley. Any shorting to earth of this wire will put the oil pressure switch on.
Oil pressure switch isn't above suspicion either.
liam012
just drove all the way to work stayed at normal operating temp - cme up to alf way on the last 1.5 miles due to traffic, pulled into work popped hood - and again the top two hoses are not firm, give them a squeeze and instantly they get red hot and and the temp gauges goes back to just under half -
also coincidently enough it started to pur rain just coming intot the low speed city zone and what starts to barely flicker? the oil light - which didnt make a peep on start up or the previous 16 miles to work -
still not convinced of it being caused by moisture though
There's no direct connection between your oil light and moisture - the impedances involved are far too low.
Your oil pressure light would still work properly at the bottom of a river!
BristolBulldog
For the price, get a new pressure switch, and inspect the wiring at the same time. Brian is right about the impedance as well. The pressure switches get weaker over time as well.liam012 wrote:just drove all the way to work stayed at normal operating temp - cme up to alf way on the last 1.5 miles due to traffic, pulled into work popped hood - and again the top two hoses are not firm, give them a squeeze and instantly they get red hot and and the temp gauges goes back to just under half -
liam012
The switch is only 1000 miles old, the wiring however upon inspection doesnt look to smart - where does that wire go to/plug into out of curiousity does anyyone know off hand?
Oil pressure switch wire comes through the engine loom from the C101 connector on the bulkhead by the fusebox.
liam012
is there a pinout for the c101 socket anywhere?
i have checked the wiring and it seems that 90% of it going along by the block is just see through plastic around a wire - only about the first inch is black insulated.
i would like to run my own fresh wire back around into c101.
i presume a slight difference in gauge wire shouldnt affect resistance too much or is it very sensitive?
Pinouts have been posted a few times in the M50 and M30 engine swap threads, but the one you want is pin 5.liam012 wrote:is there a pinout for the c101 socket anywhere?
Gauge of wire is of no importance at all.
did you use a new oil pump when you did the build?
liam012
sure did = and pencil drive
