What suspension for 5 stud conversion
buster
Post Wed Jan 17, 2007 12:18 pm
Hello all,
Im thinking of buying the stuff to convert to 5 stud.
Will my spax psx kit designed for the 325 sport fit the e30 m3 struts ?
I think the back will be the same,its just the front im unsure of.
Am i right in thinking m3's have an external front damper ie, not sat in the leg like normal e30's ?
your thoughts please gents,
cheers
andy
Post Wed Jan 17, 2007 12:21 pm
would E36 stuff go on, or would that widen the track too?
buster
Post Wed Jan 17, 2007 12:22 pm
yeah e36 stuff works and is far cheaper but i want the abs to work
Post Wed Jan 17, 2007 12:33 pm
i think* you will be able to use all off it. Even the roll bars are the same they just mount differently with M3 front struts.
Best ask M3 guys what works well! I've read 6 pot H&R 35mm springs work well on them
Dan318-is
Post Wed Jan 17, 2007 12:45 pm
You cant use the back im 99% certain of that because its a Z axle isnt it? it has to be either z3 or compact trailing arms i thought?
jmc330i
Post Wed Jan 17, 2007 1:37 pm
Dan318-is wrote:You cant use the back im 99% certain of that because its a Z axle isnt it? it has to be either z3 or compact trailing arms i thought?
If you use the E30 M3 rear arms, your 325i sport springs/shocks will fit fine. Not sure what happens if you use the Z3/compact arms though, but they should still fit - AFAIK the trailing arms are basically the same, just different mounts for handbrake cables and ABS stuff etc.
James
'91 325i Sport
'93 318i touring 16v
Simon
Post Wed Jan 17, 2007 8:01 pm
The fronts on the M3 are the same as what you have with regards to the inserts, so they can just be swopped over no problems.
The rears will also fit fine if using M3 stuff.
All M3 shocks are compatible with normal E30 anyway when comparing part numbers.
I have H&R 6 pot springs with bilsteins, and this setup works very well for me.
buster
Post Thu Jan 18, 2007 6:29 am
Nice one cheers simon.So are they 52mm inserts then ?
At least i wont have to buy a full new suspension kit also ! :D
Dan318-is
Post Fri Jan 19, 2007 11:43 am
My bad i thought you meant e36 rear susp.
