The speedo in my e30 works fine up to about 75mph but it will stick there until i slow down to 40 or tap the dash. Also some mornings the tacho will overread the rpm and a couple of taps will bring it down to the right reading. Are these releated and is there an easy fix or will new clocks be needed?
Any suggestions much appreciated.
Erratic Speedometer & Tachometer
Davenotouring
Sounds like it could be bad earths, you can remove the cluster and tighten certain screws which may help. There is a guide somewhere on this site I think!
Either that or the Service Indicator board batteries are low.
BMW 328i Cab - Daily Slag
candyman
check the connections on your diff 99.9 percent of the time this is full of crap and water or wires are breaking
if wires are not broken remove plug clean up terminals and spray with w d 40 to help connection
see if that cures it had it 3 times on my cab:(
Stuart
Stuart
