Intermittent wiper problem
Padzer
Post Mon Jan 15, 2007 10:53 pm
Wipers don't work properly on intermittent setting but work perfectly on normal and fast setting.
When on intermittent, they are fine on the "way up" but on the "way back" they basically get stuck and have to be encouraged by using switching to constant.
I;ve changed the blades and it';s still the same. Any ideas?
Steviec
Post Mon Jan 15, 2007 10:58 pm
Its down to the motor, I think theres a bit in the Articles section above. You need to remove it and clean up the disc inside, its pretty easy to do aswell.
<a><IMG></a>
Stumpy1
Post Mon Jan 15, 2007 10:59 pm
Your motor is faulty. It can be fixed by removing it and cleaning the internal contacts but my experience with mine shows this repair doesnt last long. Best to get a new unit.....
Steviec
<a><IMG></a>
cliffybabe
Powered by Nelly
Powered by Nelly
Post Tue Jan 16, 2007 12:28 am
Easy fix as above, or get a replacement motor u know to be working winkeye
wildeian
Post Tue Jan 16, 2007 12:36 am
DO THIS NOW!!
Mine wasn't working right on intermitant, and it packed up altogether tonight - when I was driving, in the rain!!
I had to use the force to get home!!
Padzer
Post Thu Jan 18, 2007 2:24 pm
Thanks for the advice people.
P
wildeian
Post Thu Jan 18, 2007 7:11 pm
I replaced mine with a cleaned up one, and it still has issues!! (similar to yours, but doesn't stop moving)
Damn these infernal machines!! :x
