Viscous fan perm. on??
wildeian
Post Mon Jan 15, 2007 10:18 am
Anyone ever had a viscous fan that was on from startup, and doesn't seem to stop?
Do they fail in this way?
Fan belt just snapped, if that could be related? (obviously the fan is not turning now!!)
I get a hell of a 'wind-turbine' noise as I accelerate, almost sounds like an automatic!! :(
Morat
Post Mon Jan 15, 2007 10:43 am
Mine was replaced about 6 months ago with a new unit. It spins on startup but not hard. If you can hear the air roaring through your radiator from startup you may have a problem but I'd say the fans always spin at least a little. I would imagine that if the thermostat is doing its job then you won't be getting much cooling anyway, the failure you need to watch for is the fan failing to spin up when the engine is hot.
Where is your temp gauge reading?
Morat
edit: ok sorry - you get the roaring noise too. Hmm I guess that shouldn't be happening, but also its better than it not working at all!
Barnz
Guildford Geezer
Post Mon Jan 15, 2007 11:13 am
My fan works from cold, ie all the time, and did the newspaper test (when warming up) and it didn't shred it, so does that mean my viscous is knackered??? Wouldn't think the fan is supposed to work from cold?
E34 525tds - on the way to replace 325i
E30 / 34 spares
Dan318-is
Post Mon Jan 15, 2007 11:22 am
The fans do always work. They run of the auxillary belt and so are constantly turning whenever the engine is on up to around 40mph iirc, where a clutch kicks in and the fan stops spinning. As said the newspaper test is worth doing but it should be running anyway with the car at a standstill as its running of a belt not of an electrical thermo-switch.
hth
Post Mon Jan 15, 2007 9:36 pm
The fan turns with the engine all the time, but with the coupling unlocked it's just free wheeling, and turns at much less than engine speed, absorbing little power when the car is stationary, and even less when the car is moving.
It doesn't make much noise in this condition.
When the viscous cuts in the fan makes a distinct roar, especially when the engine is revved.
Get the car hot, then leave it idling with the bonnet open and wait. Watch the temp gauge to make sure the car doesn't overheat, and if the viscous is working properly, you'll eventually hear the fan cut in.
Don't think I've ever seen a viscous fail locked, but it's perfectly possible for this to happen. Should be obvious with the engine stopped if you try to turn the fan.
wildeian
Post Tue Jan 16, 2007 12:33 am
Yeah, it locks if I turn it in direction of rotation, but comes free if I turn it against??
Post Tue Jan 16, 2007 12:47 am
Shouldn't do that!
wildeian
Post Tue Jan 16, 2007 12:52 am
Bugger!! :(
Post Tue Jan 16, 2007 12:54 am
You've just discovered a cheap way to gain a few BHP on your car, and you say "bugger"??
Some people are never satisfied!
wildeian
Post Tue Jan 16, 2007 12:58 am
8O ........you mean this might actually be good for me!!
At last, some good news!
