OBC differences
buster
Post Sun Jan 14, 2007 1:45 pm
Hi all,
Ive just pulled an obc loom out of a car that actually had the obc clock part missing.It has the push button indicator stalk,and the little ecu but i've noticed that this ecu that sits above the engine dme is black with 2 green connectors on it but the one on my sport is blue with 2 green connectors and a longer green connector.
Basically what have i got here is what i want to know.
thanks
andy
tomson
Post Sun Jan 14, 2007 1:54 pm
Any pics at all mate?
Ill just go dig my obc out now to compare colours, ive a full set up in a box somewhere!!
Tom
Post Sun Jan 14, 2007 2:05 pm
2nd time this week that this has come up! The box above the engine ECU is not an ECU of any kind. It's mainly empty space with two small relays tucked away in the corner. One relay is to immobilise the engine, and the other is for the alarm horn. Both only used with the CODE function.
All the OBC functions, except the CODE will work without it
buster
Post Sun Jan 14, 2007 3:25 pm
ok cheers brian,even so though,do you know the differances between the 2.
cheers
andy
Post Sun Jan 14, 2007 3:51 pm
Probably the colour of the plastic.
buster
Post Sun Jan 14, 2007 9:17 pm
Brianmoooore wrote:Probably the colour of the plastic.
LOL,yeah but the blue one has a large connector on it that the black one doesn't
Post Sun Jan 14, 2007 9:45 pm
What connects to this large connector?
Plenty of room inside the box for other things. BMW must have had something in mind.
buster
Post Sun Jan 14, 2007 11:32 pm
i cant remember as its on my sport and havent seen inside the dash for a while.
