i have a 91 e30 touring, but its only got front leccys! can i fit rears out of a std 4door? i looked under the gear gaiter and there are the wires for the switchs, will the wire be in the rear doors too??
any help ? cheers L
rear electric window converion... (touring)
318Touring
Simon
Hiya mate.
Yes, the mechs from a 4 door E30 will fit fine, it's a nice easy conversion, straight swop for the manuals.
There is a chance you may have the wiring in the rear doors, some do, some don't, just whip off a door card and take a look, if the loom running to the central locking actuator is only 2 wires, then you will need the grab the looms from the donor car, you only need the loom back into the B-pillar, as all E30's have the loom up to this plug.
All together you will need, the 2 mechanisms, 4 electric window switches, 1 small square switch to disable the rear switches, and remove the loom in the doors too.
318Touring
Simon, thank you for the reply! i will look tomorrow! cheers L
E30Mark
I'm selling a rear electric window kit if you need any bits...
http://www.e30zone.net/modules.php?name ... ic&t=55352
PM for details
PM for details
