hey zone,
i've got an 89 320i and the central locking is playing up, when i put the key in the driver or passenger side lock and lock the car the car locks and then suddenly re opens itself and also when i put the key into the lock on the boot i can't turn the key either way as it won't turn right or left. Any suggestions what could be wrong with the central locking and the lock on the boot and how to fix both of these problems?
many thanx
fraser
central locking and boot lock
Assuming your key has worked in the boot before (i.e. the boot lock hasn't been changed and needs a different key, then I suspect it's all something to do with this. It's a new one on me, and can't think what exactly the problem might be, but the boot lock mechanism dismantles easily enough.
Take out the rear boot liner panel and it should be obvious how to take it apart.
