318iS dead..Fuel pump relay??
jaistanley
Post Sat Jan 13, 2007 3:58 pm
Hi,
My 318iS wont start. It turns over but doesn't fire.
I noticed the fuel pump no longer primes when the ignition is turned on so I put 12v across the fuel pump terminals at the tank. The pump runs fine so I am assuming no power is getting to it. This sounds like the fuel pump relay has failed to me.
Where is the damn thing? I rang GSF and they said they had two types on record and I'd need to get the part number from my existing one so I need to take it out. Does anyone know which one I'll need?
Many thanks in advance..
Jai
SPADGE
Post Sat Jan 13, 2007 4:23 pm
Under the plastic cover on the bulkhead. Sits above and behind the engine and goes from fusebox across to the battery end. Not sure which relay it is under there though.
eko
Old timer
Post Sat Jan 13, 2007 5:15 pm
Orange relay where Spadge said!
Post Sat Jan 13, 2007 7:01 pm
You don't need to buy a new relay to see if it's the problem - and I doubt if it is! I expect that you have no spark either.
Pull the relay out and link together pins 30 and 87 of its socket with a short piece of wire. This will make the pump run continuously, even with the ignition off, so don't forget to disconnect afterwards.
Try to start the car with the link in place.
jaistanley
Post Sun Jan 14, 2007 12:19 pm
Ecellent Brian, cheers.. I'll give that a whirl in a bit..
You say you expect I have no spark either, do you suspect something else such as the 'dme' relay?
I have a set of plugs here. I'll fit them (as I have them), charge the battery, test the FPRelay as mentioned above then I shall know where I am.
Many thanks.
Jai
stuartgallafant
Post Sun Jan 14, 2007 12:22 pm
jai, last year my iS had similar symptoms to this. turns out that the rocker cover gaskets that are between the spark plug cylinders had correded and oil had p!ssed down onto the plugs and was stopping them from sparking
might be worth a check?
jaistanley
Post Sun Jan 28, 2007 5:40 pm
Woohoo!!!
Not sure what did it, but I got it started.
The fuel pump was dead when ignition turned on so I started there. As you suggested, I shorted the pins in the relay location (30 and 87) and I could hear the fuel pump running. I tried it then but not for long: nothing. Then I removed all plugs and allowed the oil to run into the bores, cleaned the plugs (putting old ones back in till it runs so they don't foul up) and lead ends. This time it fired once but then not again.
I then removed both the relays (the fuel pump one was orangey and the other white), cleaned the terminals and banged them about (on the floor etc) to see if one had stuck. I put 12v across the pins of the fuel pump relay (not pins 30 and 87, the other ones) and it clicked so I guessed it wasn;t the relay to blame, perhaps the white one??
Anyway, put it back together, recharged the battery again and this time it started with clouds of blue smoke (which I was expecting after letting the oil run into the spark plug holes)
So I'm not sure what actually fixed it, and now it'll probably die on a roundabout for me! Tomorrow I'm going to change the oil, de-grease the leads and holes properly and fit the new plugs.
Phew!
Thanks for the help guys...
Now for an MOT. Lame.
Jai
m-dtech
Unapproved Trader caution
Post Sun Jan 28, 2007 7:14 pm
could be crank sensor problem.... if it happens again check for spark......... if no fuel and no spark id replace your crank sensors.
pm me if required as i have some ;)
jaistanley
Post Sun Jan 28, 2007 7:38 pm
I considered this when it first died but the fuel pump not 'priming' when the ignition was turned on sways me away from the CPS... Cheers though, I'll definitly bear it in mind.
Jai
