My OBC - what's missing?
Alyman
Post Sat Jan 13, 2007 3:42 pm
Righty
Went down to the scrappies this morning looking for a few things, but by chance I stubled upon a 325i with the 13 button OBC installed. I didn't really know too much about the OBC so I wasn't sure what to take and what to leave... Having come home and read the tech article on retro fitting the OBC it seems that I don't have the indicator stalk that is mentioned - I didn't notice any extra stalks around the steering column, is it possible that it was fitted without the stalk? Or is the stalk used by the OBC a replacement for the standard stalk, which would explain why i didn't see anything extra there?
Heres the pics of what I took:
I think what I have is the OBC display and loom, I'm hoping that the two black boxes in the second pic are the gong and brain, I got a temp sensor from the brake duct and a horn from just above that (I took the brake ducts too).
So am i missing anything else? Should I be going back to have a look at the indicator stalk?
Any help appreciated!
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Sat Jan 13, 2007 3:46 pm
Yes mate you will need the stalk aswell.
Taylor.
Alyman
Post Sat Jan 13, 2007 3:51 pm
Right, so is it a case of the indicator stalk on car with an OBC is different from the standard one?
ian332isport
Taylor325i wrote:Yes mate you will need the stalk aswell.
Taylor.
You don't actually need the stalk. It will work fine without, but you won't be able to scroll through the OBC functions by pressing the end of the stalk.
Ian.
Alyman
Post Sat Jan 13, 2007 4:13 pm
OK, just read through the retro fitting guide again, so I realise that it's a replacement stalk instead of an additional one. Just my luck though, the rain is now pelting sideways. Gotta go to work soon anyway, I'll drop back in to the yard through the week and remove it. :D
Steve-E30
East Sussex Hooligan
Post Sat Jan 13, 2007 4:14 pm
Alyman wrote:Right, so is it a case of the indicator stalk on car with an OBC is different from the standard one?
The ones with obc have a button you press in at the end and says obc in small writing with a arrow pointing inwards , Obc will work fine without one , Its just a nice touch having it :wink:
Alyman
Post Sat Jan 13, 2007 4:20 pm
Yeah, I'm definitely gonna go back for it, seems like I managed to get 95% of the OBC out, it would be a shame not to have the whole lot!
orangecurry
Post Sat Jan 13, 2007 5:45 pm
I don't think you need to bother fitting what you called the 'brain' - the OBC box contains it's brain - the other bit in your 2nd photo you already have one in your car.
Having the stalk is a huge bonus - it means the paint on the buttons on the OBC doesn't wear off :D
Theo
Post Sat Jan 13, 2007 6:03 pm
You don't seem to have the OBC horn and guard plate either, but that is only used for the alarm function which I very much doubt anyone uses.
You will need to fit the 'brain' though! Non OBC cars do not have this fitted.
Post Sat Jan 13, 2007 6:48 pm
The "brain" is not what you think it is. The large black box is mostly empty space, and all it contains is two relays.
One relay is for the alarm horn, and the other is for the CODE immobiliser. The OBC will work happily without it.
Theo
Post Sat Jan 13, 2007 6:58 pm
I stand corrected - sorry :o:
Thats a very extravegant case for two relays though!
If you're going back to get the indicator stalk you may as well grab the horn, just so you have a proper full kit?
Post Sat Jan 13, 2007 7:07 pm
Theo325 wrote: Thats a very extravegant case for two relays though!
It is! Obviously BMW had other ideas for the rest of the space that never came to fruition.
E30Adam
Post Sat Jan 13, 2007 7:09 pm
You'll also need the outside temperature sensor which is found in the passenger side brake duct!
Post Sat Jan 13, 2007 7:15 pm
E30Adam wrote:You'll also need the outside temperature sensor which is found in the passenger side brake duct!
Top right of the pic, Adam.
E30Adam
Post Sat Jan 13, 2007 7:20 pm
Oh yeah, it's my age, I'm 26 now, must get those eyes tested :lol:
orangecurry
Post Sat Jan 13, 2007 8:19 pm
mine had/has one fitted :D
I got a 2nd hand OBC, retrofitted all the other bits, then swopped the 'empty box', and the car wouldn't start - so I put back the original empty box; all worked again, though as Brian said I don't use the CODE function - wouldn't dare! I had enough trouble when I tried using the magnetic key alarm (fitted as standard on the cabbie)
Post Sat Jan 13, 2007 8:22 pm
If you had one fitted, and simply remove it without linking the immobiliser wires, then of course your car won't start. If it never had the box in the first place, then the immobiliser is already linked.
orangecurry
Post Sat Jan 13, 2007 8:28 pm
no no no - I put the wires (that WERE going into the original box) into the box that came with the OBC, and the car wouldn't start...
Post Sat Jan 13, 2007 8:36 pm
orangecurry wrote:no no no - I put the wires (that WERE going into the original box) into the box that came with the OBC, and the car wouldn't start...
You've lost me, but the other end of the two immobiliser wires that go into the OBC relay box go to a white connector with two green wires going to it over the middle of the glove box.
On cars without any immobiliser this connector is fitted with a shorting link.
Alyman
Post Sat Jan 13, 2007 11:45 pm
Wow, loads of info there, I'll be interested to see what the setup is in my car at the moment - I don't have an immobiliser fitted on the car just now, but I bought an alarm t'other day, it should arrive on monday. Would it be best to wait until i have the alarm installed before fitting the OBC? I must admit i had no idea the OBC had anything to do with alarms/immobilisers!
Theo325 wrote:You don't seem to have the OBC horn and guard plate either, but that is only used for the alarm function which I very much doubt anyone uses.
I removed the horn mate, its in the top left of the picture. left the guard thing behind though cos it was really really really rusty. Figured I could mount it somewhere else or get me a new guard thing from the dealer
orangecurry
Post Sun Jan 14, 2007 8:06 am
perhaps the cabbies magnetic key security needs an 'empty box', which is why my car had an 'empty box' to start with?
Alyman
Post Thu Jan 18, 2007 8:41 am
Well, I went back to try and get the indicator stalk, but I could see no way of getting it out as the steering wheel is still on the car. Does anyone know if there is a way I can do this with the steering wheel in place? Or if anyone has any tips on how to remove the steering wheel without the key maybe they could let me know (send me a PM though, best not to post that info on a public forum! I promise to only use the info for the powers of good! :D )
IainB
Post Thu Jan 18, 2007 9:46 am
Alyman wrote:Or if anyone has any tips on how to remove the steering wheel without the key maybe they could let me know
Pop the centre badge out, loosen the main nut (dont take it all the way off yet) pull wheels towards you (this is why you dont take the nut all the way off - a wheel in the face hurts!) then nut off, wheel off and voila :D no need for the key
orangecurry
Post Thu Jan 18, 2007 9:50 am
yes there is - steering lock prevents the wheel from coming off.
Post Thu Jan 18, 2007 10:08 am
Bottom shroud will come off the steering column with the wheel in place. Top one can come off if you break it.
Steering wheel won't come off with the lock engaged - the lock engages with the outer edge of the wheel boss right at the back at the top.
If the wheel's a valueless 4 spoke, then a hacksaw and violence will work on the wheel boss. Alternatively, saw away the alloy around the hinge pin of the lock arm, or smack out the ignition barrel from the back.
buster
Post Thu Jan 18, 2007 10:36 am
if you cant get the indicator stalk you could add a button some where for it.Every time the button is pushed it will cycle the functions.Just wire it to ground.Every time the black wire (from obc to button) is earthed it will change.
Post Thu Jan 18, 2007 10:41 am
You should be able to use a wiper stalk from a car with intensive screenwash to do the job (assuming your car doesn't have intensive screenwash)!
Alyman
Post Thu Jan 18, 2007 11:48 am
Some good ideas there, cheers!
Not sure when I'll next have the time to go to the scrappies, the donor might've gone by then, but at least I know there are other options. I quite like the idea of adding a little button, maybe a modified hazard light switch or something, over by the headlight/fog switches for cycling through the functions!
