oil light coming on 320i
dicko
my oil check light is coming on computer .Oil level is fine and pressure is ok as light on dash goes out . service is due is this the cause
jonam
It may be your low level oil sensor on the sump which maybe the problem, I had the same problem on my check control unit. Hope this helps.
dicko
thanks will check that
