guys
a buddy of mine has a 318is. he is dropping 325 engine into the car i.e. engine, box, prop, ecu, engine loom, associated bits
my question is does he have to change the loom inside the car (not the engine loom) as well or does he use the existing loom inside the car.
well there be pins left over or will he be short pins??
thanks
6 Cylinder engine into 4 cylinder car
Straight swap - don't touch the body loom. There's no provision on the iS body loom for oil level sensors, so if the 325 engine has these, they just won't be connected to anything.
