Gearbox trouble
Rik178m
ok so notchy gear change, neutral no noise, no noise under acceleration or feathering the accelerator, foot completly offthe accelerator or decelerating the gearbox area rattles. Anyone know what could be wrong? A few ideas ive been told are Its knackered, thrust bearings have gone, clutch problem etc. Any help greatly appreciated.
Sounds like most E30 boxes. The rattle is normal, within reason, and nothing to worry about. Could even be the exhaust bracket rattling in your case!
For the notchy gearchange, you could try replacing the gearbox oil with ATF.
