any ideas?
brakes still seem to work fine
BMWs do not need to be bodged by"little bits of metal"!! A far better way would have been to adjust the pull rod that goes behind the heater box, since BMW went to the trouble of making the thing adjustable when they built the car.slinky2000 wrote:yea when I forst got my sport the brake lights were permently on, it was the same problem, the pedal wasnt going back up far enough. this was fixed with a little strip of metal
They only have to misbehave for a fraction of a second to put the light on until it is reset by switching off the ignition.louis2035 wrote:any ideas guys, my brake light check comes on as normal and goes off when i use the pedal, however occasionally the brake light check light comes on but the brake lights are working fine.
I has a normal thread one end and a reverse thread the other, so turning it changes its length. There will be at least one locknut on it that you need to slacken off first.slinky2000 wrote:well I didnt know it was adjustable, I never seent he pull rod behind the heater box, I'll have a look tonight.
