Posting this on behalf of a mate who doesn't have internet access.
He is going to the ring in a few months and wants to get an lsd on before the trip. What ratio is best for him?
Dave
lsd ratio for nurburgring trip
d6dph
stuartgallafant
d6dph
Oh borrocks, that could help! hehe
325i, standard car basically.
stuartgallafant
it's mainly 3rd,4th gear. I'd say 3.91 thats been fine on the times i have driven there
Theo
I rekon all the 325 ratios would be fine 3.64/3.73/3.91 there are some nice section where you can stretch the car's legs a bit, but like Simon says, you do find yourself using 3rd and 4th gear alot.
cliffybabe
- Powered by Nelly
I recon a 3:91, Its wicked on the cab, ok its only goes round the M25 ring but one day the real one
stuartgallafant
d6dph
So if I look out for a 3.73 or 3.91 we should be good?
Cheers for your help lads.
215m3
You don't want one too high as quite a few of the bends one can carry speed. You don't want to run out of revs at 110 as you will hit 125+ on certain sections.
Demlotcrew
For the sport i would suggest a gearbox with different ratios, something with a close ratio on all gears would yield better times than 3.91diff.
The 2.5s just seem to bog down on quite a sections when going into fourth.
Andrew
Andrew
d6dph
Andrew, It's just a 325i, non-sport. So if I tell him to find a 3.73??
Demlotcrew
A 3.73 is harder to find than a 3.91 and finding a LSD which has a good clutch pack in any ratio is a problem in it self.
I think he should just go for his first trip with his open diff then look into the reasons why he needs an LSD.
Andrew
Andrew
