Crazy washer jet jets
Bjeno
Post Thu Jan 11, 2007 1:38 pm
Right this has really been confusing me.
When I wash my windsceen with the normal wash (pull back) only the washer jet on the drivers side works.
When I use the intensive wash the passenger side sprays, stops, then the drivers side washes!
Any ideas why this is happening, is it a non return valve or could it be the three way split pipe connections? I tried looking at iyt to figure out what was up and the sheer amount of pipes confused me :D. Also are the non return valves etc a bmw specific part or can you get them from hell-frauds?
louis2035
Post Thu Jan 11, 2007 6:01 pm
my windscreen washer was confusing me too. similar thing happened. checked it out and three way spilt connection had cracked and washer fluid was pissing out on to the engine. replaced them now its sound.
Chris-W
Post Thu Jan 11, 2007 6:02 pm
They have separate plumbing. As said above, your t-piece needs to be replaced on the 'normal' wash.
