Temp gauge M20
Barnz
Guildford Geezer
Post Thu Jan 11, 2007 1:22 pm
On my 325 the gauge takes a long time to get moving. I'm only idling it but it should warm up ok after 10 mins or so shouldn't it?
I've checked thermostat and that's working. Some zoners have said it's the two switches on the thermostat housing, and I thought it was the fan coupling but apparently the fan runs straight from cold anyway.....
Any ideas why it's taking time to move the gauge? Engine seems to warm up ok.
Doesn't idle when cold too well.... when I blip the throttle it hunts and then stalls
Ideas?
E34 525tds - on the way to replace 325i
E30 / 34 spares
bobafett
Post Thu Jan 11, 2007 1:29 pm
Check the multiplug under the inlet manifold my friend.
Black multiplug located on the metal coolant pipe fixing bracket. Undo it check the pins if there not green (knackered) then pull the rubber boots back top and bottom to check wiring connections....
Good luck pal. :cool:
What ?! Drive straight officer......It's an E30 !
It's the Ultimate Drifting Machine.
DaveD
E30Zone Wiki Specialist
Post Thu Jan 11, 2007 1:32 pm
there is always trouble with the temp gauge,,,Sounds like the nut on the back of the gauge is loose, Just take out the instrument cluster and tighten it up
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Jan 11, 2007 2:36 pm
Barnz have u checke dthe rubber boot between the air filter and throttle body for cracks etc
Mine was crackec/ split and cause bad cold starts :mad:
Post Fri Jan 12, 2007 12:25 am
Thermostat may be working, but it sounds like it's not seating properly. Get it changed . It'll soon pay for itself in fuel savings.
Barnz
Guildford Geezer
Post Sat Jan 13, 2007 4:37 pm
Thanks guys about to go and check all these things out..... will post what happens. Don't know how I'd cope without the ZONERS!!!!
E30 / 34 spares
Barnz
Guildford Geezer
Post Mon Jan 15, 2007 11:39 am
Ok checked & tightened up the thermostat to water pump hose as that was leaking, then ran the car from cold for 10 mins..... temp gauge never went above the blue and I noticed the multiplug Bob talks about - which comes from the blue temp switch - has a bad connection right under the inlet manifold.
After 10 mins running there was a massive gurgling noise and popping and wheezing from inside the engine which I take to be a huge air lock. Stopped the engine right away as I didn't wanna do more damage. Now I'm stumped as the expansion tank was empty, two top hoses were empty of water, and I think I've cooked the engine more!
There's no gunk in the oil or water and the oil looks quite fresh, so what do I check next?
Any ideas on steps of how I can bleed the system? Tried a search on the Zone but no luck so far. How do I get rid of air locks?
E30 / 34 spares
Morat
Post Mon Jan 15, 2007 5:27 pm
To bleed it, park the car slightly nose up. Heater to full hot, fan on.
fill the expansion tank to the cold running level.
Run the engine for 5 minutes keeping an eye on the temp gauge.
Bleed the bleed screw on the top of the thermostat housing. (8mm socket, FPR can get in the way)
Repeat until you get hot air from the blower, no more air from the bleed screw and the expansion tank stays up to its mark!
Apparently the m20 is sensitive to airlocks, and since the head is easily cracked on overtemp, you'll need to be careful. I did mine at the weekend and it seems OK.
Post Mon Jan 15, 2007 8:40 pm
To get the airlock out from the back of the engine, fill the header tank up to the top, loosen the top heater hose where it goes onto the bulkhead stub, and pull the hose just off the stub, so that the air, along with some coolant comes out. Push the hose back on and refit the hoseclip.
If you feel really keen, do the same to the lower hose as well.
The connector under the inlet manifold may well be responsible for your idling problems.
Barnz
Guildford Geezer
Post Tue Jan 16, 2007 1:41 pm
Thanks Morat and Brian... helpful as ever. A mate has told me to take off the blue temp switch, which I guess is the same as taking the top hose off. If bubbles appear in the header tank then the head gasket has gone right????
Will be trying this out tonight :?
E30 / 34 spares
Barnz
Guildford Geezer
Post Fri Jan 19, 2007 12:27 pm
Finally got round to checking the temp gauge on my 325 by earthing the temp transmitter connector as it says in Haynes.
Found that didn't work, gauge didn't move, so tested the other switch connector below it (sensor for the ECU I presume) and that one made the gauge go right round to the red and back like it should do.
So basically I had the connectors on the wrong switches. Sure enough, swapped them round and the temp gauge now works 100%..... I left the ECU sensor connector off, and it ran fine in fact better than before.
What I don't want to do is connect the lower ECU one up and blow the ECU.
What I need though, to make sure is to compare engine wiring, so if anyone's following this 8O 8O , can they post pics of the thermostat housing area on their 325 with the 2 switch connectors as I'm confused as to why the connectors were fitted the wrong way round................
Cheers a lot
E30 / 34 spares
Barnz
Guildford Geezer
Post Fri Jan 19, 2007 12:33 pm
PS I'll be doing a full airlock removal at the weekend but I wanted to make sure the gauge was working right first.
E30 / 34 spares
DaveD
Post Fri Jan 19, 2007 12:57 pm
here is a link to downloadable wiring diagrams if you want them...i think they are for us cars but they might help
http://shark.armchair.mb.ca/~dave/BMW/e30/
Barnz
Guildford Geezer
Post Fri Jan 19, 2007 5:09 pm
Cheers DaveD very helpful :D
E30 / 34 spares
Barnz
Guildford Geezer
Post Sat Jan 20, 2007 7:02 pm
Barnz wrote:can anyone post pics of the thermostat housing area on their 325 with the 2 switch connectors as I'm confused as to why the connectors were fitted the wrong way round.........
Thanks guys :)
E30 / 34 spares
