Does anyone know how you can test the abs as i've had my 1986 325 for 3 years and i've never seen the abs light come on.
Win
abs
Chris-W
chrisr29
Yeah, stamp on the middle peddle on an empty peice of road (preferably in the wet) and see what happens. If your wheels lock up then it's broken. If they don't and the pedal pulses then it works.
win
cheers guys i'll give that a try, but if its broke is it expensive to replace and could i do it myself?
Win
Win
Chris-W
Light should come on with ignition. If it doesn't it's probably not there - and usually for a reason.Chris-W wrote:
If the light isn't on, it's most probably absolutely fine.
First thing to do is check that a working bulb is in the ABS warning light holder. This lamp is different from most on the cluster, in that it has flying leads and just pushes into the back of the cluster.
win
Cheers guys i'll check behind the intrument panel because mine does'nt come on with the ignition
win
win
