What's the correct accessory panel socket for...
Royalratch
Post Thu Jan 11, 2007 11:55 am
...Maplight Rear View Mirror.
Can I get the correct plug for it from any electrical store or BMW only?
Closest part diagram I can find is this:
http://www.realoem.com/bmw/showparts.do ... g=61&fg=15
Thanks all!
miniblob
Post Thu Jan 11, 2007 12:34 pm
I struggled to find plugs to fit this - got lucky when a local breaker was stripping an e30 and he let me just pull some out and have 'em - then i just joined the wires to the plugs and it worked spot on!!!
Think finding someone breaking one is your best bet!!
327 Touring with bass!!!
Royalratch
Post Thu Jan 11, 2007 12:39 pm
Or I'll just get some rpuond end connector and plug them in. Do you knwo where in the panle they go?
Brianmoooore says BMW do not use black and grey as wiring but I have one with Black (I assume is live) and grey which I assume is earth.
Post Fri Jan 12, 2007 12:37 am
Royalratch wrote:Or I'll just get some rpuond end connector and plug them in. Do you knwo where in the panle they go?
Second down on the right, I think.
Royalratch
Post Fri Jan 12, 2007 10:17 am
Cheers Brian,
Does it matter which color goes in which hole?
Does on of them have to go to the earth clamp under the glovebox?
miniblob
Post Fri Jan 12, 2007 2:14 pm
I couldn't find any round/bullet connectors that fitted properly!! The BMW connectors seem to be shaped - but you might be lucky!!
As for where in the panel - i just got my multimeter out and had a play!! Found a few different voltages and some that are constant and some just on with the ignition!! Some didn't seem to do anything at all!!
Royalratch
Post Sun Mar 04, 2007 5:16 pm
Brianmoooore wrote:
Royalratch wrote:Or I'll just get some round end connectors and plug them in. Do you know where in the panel they go?
Does one wire have to go to earth or does the accessories panel take care of live and earth?
SPADGE
Post Sun Mar 04, 2007 5:26 pm
Ratch the correct wire has one plug on the end with 2 wires one for earth and one for live
Got one here i'll take a pic later for you.
Royalratch
Post Sun Mar 04, 2007 5:55 pm
Cheers buddy.
I basically extended 2 wires from the maplughts down to the accesory panel but now have to figure out what way to 'fix' it to the panel.
Some kind of female bullet I guess - it's bare wire at the mo.
Royalratch
Post Mon Mar 05, 2007 10:39 am
I guess what I really need to know is which connectors/pins connectors from BMW are the ones you need to order to make 'factory connections' to things like the accessory panel, foglight and temp sensors etc.
For example?
Or does BMW use industry standard bits that I just don't know about?
Demlotcrew
Post Mon Mar 05, 2007 10:41 am
Brian you are always telling people it connects to the C302 but its no where near there.
I have the part number for the loom if any one needs it.
Not sure how much it is from BMW tho.
Andrew
SPADGE
Post Mon Mar 05, 2007 10:53 am
Here you go mate
It has the same plug both ends.
SPADGE
Post Mon Mar 05, 2007 10:57 am
The plugs have a number on them that is so small i can barely read it but it ends in 229 so none of the above.
Demlotcrew
Post Mon Mar 05, 2007 10:59 am
Yup thats the loom,
Wonder if BMW still stocks them.
Andrew
Royalratch
Post Mon Mar 05, 2007 11:01 am
But surely I can order that plug at least?
Could it be No 9:
And the pins that go inside?
What are they called?
Thanks for the pic bud.
SPADGE
Post Mon Mar 05, 2007 11:10 am
What is the part number for number 9 mate?
It looks right as this one has the small flat piece on it as per your pic.
Royalratch
Post Mon Mar 05, 2007 11:14 am
09 WIRING S.R.S.GAS CARTRIDGE 61121377878 $20.20
But if I need to make up new looms etc where do I get just the female and male pins that fit inside? Are these BMW only?
SPADGE
Post Mon Mar 05, 2007 11:28 am
Royalratch wrote:09 WIRING S.R.S.GAS CARTRIDGE 61121377878 $20.20
Its not that one then.
Give bmw a shout and see if that loom in my pic is still available.
Royalratch
Post Mon Mar 05, 2007 11:43 am
May still be the same loom, just different use. I'm sure they use the same connectors / looms for more than one job.
Demlotcrew
Post Mon Mar 05, 2007 12:15 pm
Just been to BMW £2.72 but its NLA
Andrew
Royalratch
Post Mon Mar 05, 2007 12:19 pm
Buggah.
So what do I do?
Can anyone tell me if those pugs/pins are available elsewhere?
Demlotcrew
Post Mon Mar 05, 2007 12:26 pm
They are used all over the E30 it would be dead easy to make a loom like this from bits off other looms cut out of scrap cars.
Andrew
Royalratch
Post Mon Mar 05, 2007 1:40 pm
Yeh but are they available new? I don't live anywhere near a scrap yard and don't even have the time to get to one.
Phoning BMW with a list is the best way.
SPADGE
Post Mon Mar 05, 2007 1:55 pm
Just so as you know the connection to the loom for the mirror is behind the passenger side speaker
Post Mon Mar 05, 2007 2:14 pm
SPADGE wrote:Just so as you know the connection to the loom for the mirror is behind the passenger side speaker
Ah!!! Was beginning to suspect there must be another connector somewhere. Second down on the right of the accessories socket is a direct feed from fuse 6, so is the correct supply for the map light, but the one beside it isn't earth. It's official purpose is for cruise control.
Royalratch
Post Mon Mar 05, 2007 2:42 pm
There's also a dual wired plug that looks like it's coming from the door tweeters there too right?
